1 - 11 of 11 Posts
Its a 6+2 PCI-E connector from a Corsair HX650W.
Would I be able to just cut the wires right where I drew the lines or would it cause some kind of problem? I'm about to sleeve this and its kinda hard to sleeve it with those 2 extra wires that I don't need since I'm only using x2 6 pin PCI-E for my GTX470.
Basically I don't need cables 7 and 8 can I just cut them off without having any problems?
Any help is appreciated.
i have no idea but if i had to guess i would say its okay as long as you seal them properly, you could get nasty shock if you touch them after cutting em with pc on.
If you don't let them touch components you should be ok, make sure you cut as short as possible. Both of the +2 wires are grounds so if they touch it's ok.
Chainsaw noise far off
I have done it before on a fan 3 pin adapter with no adverse affects.I cut off where it splits to a molex power connector,basically looked the same as what you have.So it's a yes just be sure to trim it back like it wasn't even there.
Guess I'm Back
Won't cause any problems as long as you insulate them properly, but I would highly advise against it. It would suck to cut the wire and then upgrade your GPU only to find out you needed those extra two pins. I would heatshrink the ends and tuck them out of the way somewhere out of sight.
Reactions: b0klau
Discussion Starter #7
Unless anyone has a way to sleeve the whole thing including the extra 2 pins I'll leave it. Thanks guys +rep
There is, I did it. Let me get you a pic.
Discussion Starter #9
Please
Ok, here you go.
This is from an AX750, 12 pins on the side that plugs into the power supply, but a pair of 6+2 (16 total) on the other side. It is same as yours, where two wires are spliced into one connector. I basically sleeved each wire individually as I would if they were alone. So two sleeved wires coming out of one connector, each with it's own heatshrink etc. The final connector is wrapped in a huge piece of heatshrink but I can cut it open to show you if you want (got plenty more since I only need to sleeve one more wire like that).
1 - 11 of 11 Posts
