1 - 8 of 8 Posts
I'm NOT new to Overclock
Shouldn't do. It should be ok
Reactions: frickfrock999
Out of curiosity, what would you do with more than 1?
It should be just fine, if you think about it; it shouldn't use much more power than a normal controller. It's basically a controller built into a steering wheel with a few extra's.
You shouldn't have any trouble. I'm pretty sure USB ports are limited to a small amount of power anyway, so they can't even pull much power. If it was made to pull a lot of power it would have an external power source.
1 - 8 of 8 Posts
