Hey, been a long time since I've posted here.
This would replace a near-dead Logitech Z-5500 system with severe crackling speakers that's 15 years old. The reason I'm going with a traditional receiver is that the Xbox Series S and PS5 no longer have optical out. I want to spend as little as possible while also getting an upgrade in sound from my Z-5500 digital system. I recently got 200 BluRay movies from someone that switched solely to streaming and I want to utilize the True HD and DTS MA tracks on the discs and apparently the PS4 does support that but only via HDMI.
Front + Back speakers
Center Speaker
Subwoofer
5.1 Receiver I'm likely to get
Much more expensive 7.2 receiver I might get due to more HDMI inputs
An alternative option that wouldn't support current-gen consoles is.
Logitech Z906 5.1
I have a few questions/comments regarding the home theater system.
First off, the center speaker is 6ohms, the other speakers are 8ohms. Will that be an issue ?
Technically the front speakers are supposed to be using a set of different tall 6ohms speakers, but that set also uses the same 8hms speakers as rear speakers, will that make much of a difference ?
The Z-5500's didn't have tweeters so I don't think there would be much of a difference in the systems.
I'm contemplating getting a set of these for my PC to replace my 2.1 Klipsch system as the sub has blown out, but the Klipsch system has tweeters so I wonder if the Logitech set would be a downgrade.
I noticed Amazon has nearly every receiver listed as 'discontinued by the manufacturer' so it's hard to find anything under $1k on there.
Is that subwoofer compatible with the receiver ? I read something about having to change things on the back.
Center Speaker
Subwoofer
Logitech Z906 5.1
