1 - 9 of 9 Posts
ASUS P5B Deluxe/WiFi-AP Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard<br><a href="http://www.newegg.com/product/product.asp?item=N82E16813131028" target="_blank">http://www.newegg.com/product/produc...82E16813131028</a><br><br>
I ask this b/c I finally got enough cash to get most the parts I want for my PC. I am going with a Conroe E6600. BUT I was wondering if a year from now or however long it takes for games to start using quad core if I could use that same MB to upgrade to a Kentsfield.
yes, this board supports all the Pd's all the core 2 duos and it probably will support kentsfield when it comes out with a bios update, but that one im not sure about.
sweet ! Thanks bud
At this time I think it's impossible to say if it will support kentsfield. But it will work with all current LGA775 processors.
<tr>
<div>
Originally Posted by <strong>Fishie36</strong>
</div>
<div style="font-style:italic">At this time I think it's impossible to say if it will support kentsfield. But it will work with all current LGA775 processors.</div>
</td>
</tr>
</table>
</div><br />
I said likely since kenstfield is literally two conroes glued together.
0614 bios updater on this board supports kentsfield chips and all conroe and allendale cores and o/c,s like a *****
looks like it will support kentsfield. Heres an article about overclocking kentsfield on the asus p5d deluxe.<br />
<br />
<a href="http://xtreview.com/addcomment.php?id=620&view=intel-kentsfield-overclocking-on-Asus-P5B-Deluxe" target="_blank">http://xtreview.com/addcomment.php?i...sus-P5B-Deluxe</a>
If you read the BIOS notes for the P5B you can clearly see that it supports Kentsfield. From the ASUS site:<br><br><div style="margin:20px;margin-top:5px;">
<table border="0" cellpadding="6" cellspacing="0" width="99%"><tr><td class="alt2" style="border:1px inset;">P5B Deluxe Beta BIOS version 0706<br>
1 Enhance CrossFire performance.<br>
2 Enable NVIDIA 7950GX2 display under crashfree mode<br>
3 Fix CPU frequency not correct when use ES CPU and lock free fuction enable<br>
4 Fix memory display message not correct under multi-language<br>
5 Add Kentsfield B3 uCode</td>
</tr></table></div>
Hope this helps
See here:<br><a href="http://anandtech.com/mb/showdoc.aspx?i=2848&p=1" target="_blank">http://anandtech.com/mb/showdoc.aspx?i=2848&p=1</a>
1 - 9 of 9 Posts
