would this psu power it?
415 Views 9 Replies 8 Participants Last post by  shedokan
I'm ordering a new psu and gfx card..
I'm planning to get:http://www.newegg.com/Product/Produc...82E16817139003
Or:http://www.newegg.com/Product/Produc...82E16817341010
and:http://www.newegg.com/Product/Produc...82E16814130339
my system:
CPU:e2180 @3.2 ghz
2gb ddr2 corsair 5300
1 120Mm fan 2 80 mm fans
1 dvd drive
1 320gb hard drive
ty in advance.
1 - 10 of 10 Posts
oh,
I'm on a budget of 210$ for a new gfx card and psu,
so ocz it is.
tyvm
Corsair PSu's are very solid, one of the best IMHO... I would spend a bit more , but get the 550W Corsair unit
yes, i agree, get the VX550W version. Its rock solid and amazing Quality/Power.
The vx450w will perform better than the ocz in terms of solid power flowing through. compare how many amps are on the 12v rail on both PSU's. i know the 450 has 32A and the vx550w has 41A. chech the OCZ 12v rail power.
Get the 650 W if you can stand non-modular
(I'm waiting for mine to come in the mail)
Dont bother with the 9800GTX, just wait for the GTS 250 512mb to drop... since it will only be $130 soon, or you could just buy the 9800gtx anyway, maybe it will be even cheaper than the 250
Alright,
i'll get the corsair vx550 and 9800gtx then.
ty for all your help
1 - 10 of 10 Posts
