1 - 5 of 5 Posts
Can i get one of these without water cooling it. could i install it and not hurt anything? Its for a gtx 470.
It's just a backplate, You shouldn't need to water cool your card with it on.
However, you will need longer screws.
I'M NOT SURE THOUGH
Where could i find some of those?
Find out the dimensions (length, major/minor diameter) you will need of the screws and go to your local Home Depot.
Oh Ok thanks.
Any other input on this?
1 - 5 of 5 Posts
