1 - 13 of 13 Posts
Okay his the conundrum, I already decided the water cooling system I'm getting, then i thought of this idea, was just wondering if it would work.
It would be the 250mm T-virus res, with the XSPC Rasa 750 RS360 Universal CPU / Triple Radiator Water Cooling Kit.
Would it work if i use the fill port on the T-virus res? It would have to be filled to the rim right?
And would the pump be strong enough to work efficiently?
And two more questions, could i reverse the direction of the flow and still be okay? Just the cpu would get the heat from the gpu's. Also would the pump be strong enough to work efficiently if i reverse the direction?
· Premium Member
I would advise against having a second radiator unless you're cooling GPUs with heat output similar to 470s or above. The 800D lacks intake as soon as you cover up the top with a 360 rad. You're already only left with the back and the bottom fans for intake. I think anyone wanting to do a big loop in a case should consider this: http://www.overclock.net/case-labs/9...-shipping.html
· Watercooling Enthusiast
It'll work. I have 2 reservoirs in my loop as well as 5 radiators. Loops can get as complex as you want them to. The more radiators you have the better your rig will perform since it has more heat dissipation ability. Don't let anyone tell you differently. That pump/res combo can handle it, just ask wermad. He ran that res/pump combo with a rx 360 and rx 240 rad as well as a tri sli 470 setup.That setup will only work if the helix res is completely full.
· Premium Member
Why not put a pump in the bottom HDD rack? Are you using it (the hdd bays, that is) Cos then you could get a dedicated pump, and only use the t-virus res instead of using a pump-res combo plus another res. It would simplify everything. just a thought...
^Yep. Rads these days are very unrestrictive, so flow away.
1 - 13 of 13 Posts
