1 - 19 of 19 Posts
Twin Turbski
In case you've been hiding under a rock, we've had some issues with wPrime v 2.10, so this is a re-run with version 1.55 to compare and contrast results.
First, go to benchmate.org and download benchmate v0.10.8 (488MB, but contains many many benchmarks to keep us busy for a while with future competitions)
Open benchmate and select wPrime and launch the program:
Rectangle Font Parallel Screenshot Pattern
Run the 1024M benchmark:
Rectangle Product Azure Font Screenshot
When the test has completed, bring up CPUz and take a snip of both your result and the CPU-z main tab so we have the relevant information your system/overclock:
Rectangle Azure Font Screenshot Parallel
Twin Turbski
Discussion Starter · #8 ·
Thanks for the interest guys!
I will be working on the leaderboard either later tonight or in the morning. Going through a windows 11 install right now.
Newb to Overclock.net
Will this be the New World for poorly soldiered CPU's? If so, will sign up later.
9900K at 5.2GHz 0AVX 49X Cache:
Rectangle Font Screenshot Parallel Software
Twin Turbski
Discussion Starter · #15 ·
9600KF @ 5.3GHz 0AVX 45X Cache:
Rectangle Azure Font Screenshot Computer
Sorry about the delay. I re-imaged this machine with a fresh install of windows 10, I'm installing office right now so I should have the leaderboard up tomorrow.
Question: how much does cache speed relate to score?
Just hangin' out
Not doing the benchmate thing, but my 24/7 settings:
Rectangle Font Line Screenshot Software
1 - 19 of 19 Posts
