1 - 9 of 9 Posts
I just got my X-Dreamer 2, going with a Shuttle an35. I have most of the front wires figured out. Where does the red/black twisted wire go? it has a 2 pin female connector. Alson the case came with a box of screws and stuff. in the box was a connectorit has 2 wires, plug on one end and a round object on the other end for?
Originally Posted by SpencerM
Check your mobo instructions to see where to put all of the wires from the front of the case
yea i am, there is no marking on the red/black wire, and i dont want to just stick it in a place
ya, but if the speaker isnt connected, and you do have a problem and you cant hear it... well your screwed, e.g. you have MBM5 to go off when the cpu reaches a certain temp, and your mobo dosnt have an automated Max core temp shutdown, well then your probably going to fry your chip.. i think... lol
1 - 9 of 9 Posts
