1 - 1 of 1 Posts
X-STAR DP2710 LED 2560x1440 QHD PLS Panel by samsung Monitor DVI-D GLOSSY Screen
Description:
Please check out before buying.
- Only for PC monitor (one DUAL LINK DVI-D port)
- X-STAR monitor Defective standard (up to 5 white pixels are normal)
- By-Pass model (No Ad board in monitor - Monitor use graphic card resource)
- PC graphic board should surport DVI-D(Dual link DVI)
- On-board graphic card can not support WQHD.
- PC graphic card should surport WQHD(2560x1440)
Important notice for Safe usage
Recommended Graphic cards
- NVIDIA: GTX460 or more than 1GB memory, with DVI-D Port
- ATI: HD6850 or more than 1GB memory, with DVI-D Port
Dual Monitor configuration recommended
- GTX580 or HD6970. The GPU shoud have 2 dual linked DVI port.
- Please use DVI-D port only. cannot used with DVI-I or DVI-S. Also cannot be used by port converter. (D-sub, HDMI, DP)
* Onboard graphics and APU chipset is not compatible.
* Laptop or laptop with docking station and Macbook series does not recommended for this kind of By-pass (DVI output only) model.
* As P67 Chipset mainboard may show Booting skip error, and also the screen may not work out properly.
X-STAR DP2710 LED 27" 2560x1440 Monitor Specification
Condition : New in manufacture box
Model :DP2710 LED br>
Screen Size : 27 inch(68.14cm) Wide
Display Technology : LED
Panel : SAMSUNG PLS
Max. Resolution : 2560 X 1440(WQHD)
Video inputs : DUAL LINK DVI-D
View Angle : 178° / 178°
Speaker : 3W + 3W
Consumption / Standby Power : 43W / 0.5W
Respond Time : 8ms(GtoG)
Aspect Ratio : 16:9
Dynamic Contrast Ratio : 50,000:1
Static Contrast Ratio : 1,000:1
Brightness : 300 cd/m²
Vesa Mount : 100 x 100 mm
Function : Tilt
Weight : 5.2 kg(11.46 lb)
Details:
DetailValue
BindingElectronics
BrandX-Star
EAN8808764707492
Feature2560x1440 High Resolution WQHD Panel / 45W Low power consumption.
178 wide viewing angle / LED backlight / Bypass board / Brightness 300 cd/m²
GLOSSY type screen / Piano-black high glossy slim bezel / TILT stand / Dual DVI-D
3W+3W Built-in speaker / Space-efficiency using walls(100X100 VESA holes)
Beautiful images with 50,000 levels contrast ration / 8ms Respond time
LabelX-STAR
ManufacturerX-STAR
ModelDP2710 LED
PublisherX-STAR
StudioX-STAR
TitleX-STAR DP2710 LED 2560x1440 QHD PLS Panel by samsung Monitor DVI-D GLOSSY Screen
Item Height18.22 inches
Item Length25.43 inches
Item Width2.24 inches
PackageQuantity1
ProductGroupPC Accessory
ProductTypeNameMONITOR
Item Weight11.46 pounds
1 - 1 of 1 Posts
