the x16+x4 or x8+x8 refer to the speeds (/modes) your first and second pci-e slots will run at when two graphic cards are present. To answer your question, 8x+8x is the best, as most cards will be bottlenecked by the slow x4 slot of the x16+x4 setup. Only highend/dual-gpu cards will be bottlenecked by the x8+x8, so budget and mid-range cards will be fine.
HOWEVER, you said your mobo doesn't support sli, which either means its an older amd mobo, or it only has ONE physical pci-e slot, in which case everything in my first paragraph becomes irrelevant.
Either way, i would highly recommend getting one decent gpu, such as an ATI 5770 ($165). Best performance per the dollar, dx11, and supports eyefinity, which means you can use both monitors during gaming.
Overclock.net
