1 - 7 of 7 Posts
At this very moment, ATiTool reports my X1600PRO at 55C...With the 3D View open for about a minute it hovers around 67-68...
It lags in CS 1.6...which is depressing...drops from 100+ to 20 in seconds somtimes
Is this good? The fan only reports 39% power with load...26% idle
PS: No overclock, stock temps
I'd say those temp are normal... you should report this where you bought it... Its not normal because i have the 9600xt an i play with more than 120fps in CZ and 150 in cs1.6 ...
Your gpu is defenetly very hot... and in load it gets very very hot... so it reduces your performances...
Replace it...
Hey, not to mention the X1600pro (agp) SUCKS...
My Radeon 9500 at stock speeds got the same fps (+-5) in CS:S
When i unlocked the 9500 it ran glitchy, but 20fps over the highest I can get out of this pos. Got it from eBay, bad idea. 180 dollars well spent no?
Only difference between the new and the old cards was the 270% performance increase in 3dmark05....why not a 270% increase in GAMES...where it matters....
RAWR
1 - 7 of 7 Posts
