1 - 4 of 4 Posts
When ever I play COd2 my pc crashes back to windows giving me a driver error response, Im running catalyst 6.9 and at stock speeds and fan speeds are set to maximum. Tems are 49c idle and 75c under load.Any one know what may be causing it?<br />
<br />
Thx
<tr>
<div>
Originally Posted by <strong>ThaWaxShop</strong>
</div>
<div style="font-style:italic">Do you have the latest version of .net framework?</div>
</td>
</tr>
</table>
</div>Yup
is it giving you the VPU recover error? Or is it an error from the game?<br><br>
It should not be your temps, your temps will be fine upwards of 80c.<br><br>
If you are getting the VPU recovery error, you might want to try different drivers. I used to get them everytime I went in game, but then it stopped shortly after I installed 6.8 Catalyst control center.<br><br>
If that doesnt work, try reinstalling the game. If you are able to play different games without the error, then it most likely is COD2 and a reinstall might fix it.
1 - 4 of 4 Posts
