1 - 19 of 19 Posts
Soooo... until I decided to OC with my new board/mobo/grfx combo I never even thought to check out the core clock, but now that I have, my grfx card seems to be pooped.<br><br>
Has anyone ever seen an issue like this before? I'm planning to call ATI/AMD and ask them about it, but I may just have a borked card. It is an ATI brand card as well.<br><br>
I used ATI tray tool and let it auto clock/test and it will run stable at 570mhz... so, still nowhere near what the STOCK speed should be. <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"><br><br>
ATI's site reports the X1900XTX as being 650 core... I weep at my 500.<br><br><br><br>
--memory's under reporting at 600mhz (1200ddr) as well.
Make dang certain you're using the newest version of AtiTool to check those speeds. It's pretty unlikely that your card came shipped at 500Mhz.
yea, pretty sure it's the most recent. Both ATItool and ATI Tray Tools reported 500/600<br><br>
Can someone post the current versions they're using so I can check? (I'm at work, but I'll post my own versions when I get home in an hour or so)
hrm im having the same problem it seems :O<br><br>
very odd... my gpu core is at 500 flat and my mem is at 594 :S also when i run 3dmark05 "only one i have installed atm" it wont do the 3d test it says sumtin like unable to access the dll file or sumtin :S<br><br>
il look into this maybe try the latest cat verison. im at 6.9 atm..
The reason is that your GPU is runnin in 2D. Once you start playing games or anything that requires more power, it will brings itself up to 650/775
Reactions: Thranx
is there a way to force it to be at full mode 24/7 and 3dmode?<br><br>
i even tried to download a 3d background and usethat while checking the specs of the card.. and it dont change <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"><br><br>
so how do u go about ocing a card if it goes up automaticaly when it needs to :S?
<div>Originally Posted by <strong>uberjon</strong> <a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1386337#post1386337"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">is there a way to force it to be at full mode 24/7 and 3dmode?<br><br>
so how do u go about ocing a card if it goes up automaticaly when it needs to :S?</div>
</td>
</tr></table></div>
Just use the artifact detector in ATITool, that will make the card go into 3D mode and under the "Currect Clocks" area, you will see the actual 3D clock speeds.
Reactions: Thranx
Discussion Starter #10
and where is this "current clocks" area? sorry, I've looked all over in ATITool and can't find it.<br />
<br />
Note I'm running ATItool v0.25 Beta 10
<div>Originally Posted by <strong>Thranx</strong> <a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1386442#post1386442"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">and where is this "current clocks" area? sorry, I've looked all over in ATITool and can't find it.<br><br>
Note I'm running ATItool v0.25 Beta 10</div>
</td>
</tr></table></div>
It's in the top right corner of the ATITool control panel (window that you see right away when ATITool launches) I would reccommend upgrading to beta 16 though just to stay up to date <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
</td>
</tr></table></div>
Even though you can keep it 24/7, I wouldn't recommend blasting your card at that setting 24/7. Mainly because it generates unnecessary heat and especially when you don't need it [when you're not playing intensive 3d games or doing other types of work]. My word of advice <img alt="" class="inlineimg" src="/images/smilies/cool.gif" style="border:0px solid;" title="Cool">
I have the same probelm. I read online that the card needs a 450w psu and 30amps on the +12v rail. I have a 650 with 20a and its running at 506 core and 594 mem. I ordered a ocz powerstream with 33a on +12v rail and hopefully it will fix the probelm. I will let you guys know.
Check my FAQ about overclocking those cards with ATITool. This FAQ is based on Beta 14.<br><br>
It's not a good idea to run them at 3D clocks 24/7.<br><br>
I make a 3D profile (overclocked) in ATITool and use it when I play games. You can configue ATITool also to switch automatically upon recognition between 2D and 3D .
this might sound like a stupid question ... but is ati tool better than the overclock utility that comes with ccc.... i am thinking about giving it a try
Administrator
<div>Originally Posted by <strong>Vanorge</strong> <a href="showthread.php?s=5f012238fa36186cbb85825ea8d4fba8&p=1387364#post1387364"><img alt="View Post" class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" style="border:0px solid;"></a></div>
<div style="font-style:italic;">this might sound like a stupid question ... but is ati tool better than the overclock utility that comes with ccc.... i am thinking about giving it a try</div>
</td>
</tr></table></div>
Yes in general ATI tool is a little better. Comes more to user preference though.
CCC loosens the GDDR timings quite a bit.... thus ATITool will be better for the memory overclock.
1 - 19 of 19 Posts
