EDIT
Fixed it... turns out I needed a single-link cable instead of a dual-link, even though dual is supposed to work with both.
Hey, I'm having trouble with getting my LCD monitor to work properly with my Sapphire x1950 GT AGP card. The card has 2 DVI-I exits. Everything works fine when using a DVI-I to VGA adapter and a VGA cable to connect it to the monitors VGA input (it has both DVI-D and VGA) The problem is that when I try using a DVI-D cable to connect the two, I get no signal to the monitor. CCC doesn't detect that anything, even when I set the monitor to DVI input mode. The connection schemes looks like this. Working: Quote:
![]() Might it be a software/driver problem? |
