1 - 6 of 6 Posts
The XT is better in some places...but it is incredibly close. The X1950Pro has a 80nm process which means its is cooler and the fan is better as well. The XT can be noisy but since it has the full shading power, it is more powerful in some areas. I think teh X1950Pro is $199...the XT may be a little more..<br />
<br />
My pick: X1950Pro
Hmm, i'll try and find some. Hold tight...<br />
<br />
ALSO, there is not dongle with the X1950Pro if you want to crossfire and it doesn't need a master card. Although you CAN crossfire with an X1950XT if you wish.<br />
<br />
There you go, some DX9 and OpenGL apps. Also, there overclocking resluts aswell...hmm, this is interesting. Maybe the XT is better. Its the shaders. But remember this is the 512 XT.<br><a href="http://assets.overclock.net.s3.amazonaws.com/6/60/60da03b5_vbattach33828.bmp"><img src="http://www.overclock.net/image/id/616588/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/0/02/02b34dce_vbattach33829.bmp"><img src="http://www.overclock.net/image/id/616587/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/a/ab/abc3c5b4_vbattach33830.bmp"><img src="http://www.overclock.net/image/id/616586/width/525/height/525/flags/LL"></a><br><a href="http://assets.overclock.net.s3.amazonaws.com/e/e5/e50143d1_vbattach33831.bmp"><img src="http://www.overclock.net/image/id/616585/width/525/height/525/flags/LL"></a>
Filthy Casual
Couldn't find any benchmarks for the x1950PRO yet, but it did just come out.<br />
<br />
Considering the small difference in performance some have said you can expect, and the fact that the 1900XT is being phased out, and is thus more expensive, I would have to recommend the 1950PRO.<br />
<br />
I'll post benchmarks once I get mine <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<a href="http://www.pureoverclock.com/story.php?id=927" target="_blank">http://www.pureoverclock.com/story.php?id=927</a><br />
<br />
More reviews <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
Mine runs oblivion at max at 1024 no probs. Avereage of 52 fps.
1 - 6 of 6 Posts
