Originally Posted by Thundergod989
does anybody know if the opty 165's O/C just as well as the 180's? I've seen a few reviews and they all say the 165's ramp up as high as the 180's and higher in some cases... they are also cheaper and more abundant.
If you mean that can the Opteron 165 reach the same potential maximum speed as the 180? Most likely, yes. They are architecturally identical except for the maximum CPU multiplier (x9 on the 165, x12 on the 180); CPU multipliers come into play when considering the capabilities of your motherboard. If your motherboard's HT ("FSB") can scale really high (say, 340MHz+) with stability, then the 165 is the better choice because it's cheaper. If your motherboard doesn't hit high HT speeds, then the CPU with the higher CPU multiplier is the wiser choice.
Hope this helps!
