X2 driver update of single core?
315 Views 3 Replies 4 Participants Last post by  ENTERPRISE
I was wondering if i could use the dual core driver for a single core CPU?
1 - 4 of 4 Posts
Why would you do that? just use the right ones for your cpu.
Usually when you try something you know is not going to work, bad stuff happens
That woll make no difference mate. Infact it may cause the system to use your CPU in a DIFFERENT way due to the patch and may make life worse.
1 - 4 of 4 Posts
