1 - 3 of 3 Posts
i just built a x2 4800 comp for my firend, and i just read that there is a hot fix for amd X2 CPUs but it was an old article, do is still need to do that or is it something that was a problem when dual cores first came out and it has been fixed?
if you havent got the hotfix from microsoft then i suggest you download it.<br />
<br />
In future builds of windows the hotfix will be built in ( i hope )
I agree with mootin, the problem was supposedly fixed, but the Windows update version really does nothing for most people.<br />
<br />
The best method to follow is in this guide:<br />
<a href="http://www.hardforum.com/showthread.php?t=983781" target="_blank">http://www.hardforum.com/showthread.php?t=983781</a><br />
It covers all of the possible methods to fix dual-core performance in Windows XP.
1 - 3 of 3 Posts
