x3 720BE -> X4 Really wierd happenings. Come See lol.
1124 Views 16 Replies 7 Participants Last post by  arekieh
This is messed up. I stress tested it for one hour with occt and its totally stable. But speedfan gives the temp as zero. same with coretemp. CPu-z gives wierd stuff for cpu info. and same with amd overdrive. heres what it says:.
This is a 0904 chip btw.
1 - 17 of 17 Posts
-256 C damn yea that is weird. What are your voltages by any chance?
downgraded to overdrive 2.1.4 and its at 0 degrees
It happens to me as well when I enable ACC. I think it's a weird glitch with ACC enabled.
How do u monitor temps then?
you have Cool n' Quiet on? I don't and mine works fine. Also are you clocked at 3.9Ghz
im at stock ya i have cool and quiet im still on stock settings. ill go try turning all that crap off
Yeah you might want to. Equivalent of C1E for Intel CPUs I think. How you liking the rig so far?
Its great.
Just disabled it. still getting this BS in overdrive and all the other progs.
In bios sys temp is 33C
CPU temp is 18C ROFL
5
Originally Posted by falven
Nice temps, you running some absolute zero? Lol
Lol
Originally Posted by Slipp
How much for your cooler?
999999999999999999999999999 $
Anyways, I disabled ACC and now its showing properly as a 720 BE
Temp is 25C idle though
overclocked to 3.5ghz on stock volts. just moving multi up
I have the same temperature monitoring problems with the 4th core enabled.
did u get it fixed? was urs stable as well?
My motherboard health monitor(in the BIOS) reads the correct temps. Haven't found a windows program that reads the correct temps though. My 4th core is stable at stock and at 3.6Ghz, but the heat output at 3.6GHz 1.45 Volts is unbearable. I'm going to post a screen-shot of 4 cores 3.2Ghz prime stable 1.38 Volts in a bit.
0.o good idea ill try installing that
1 - 17 of 17 Posts
