Closer to the truth
I've been following this post for a while now, being the proud owner of a P5E3 Premium AP
[email protected], X48, Q9550, 8Gb and I've been wondering about all the max memory claims for quite some time.
agentx007 posted that BIOS is a limitation, but that is wrong.
For a while, around 2007, in AMIBIOS, there was an option called Memory Remap Feature where you could force your system into legacy mode (3GB Max).
That is where the limitation came from. Look it up. Also, BIOS itself doesn't report max memory, it query the chipset for a number and then randomly tests a few random addresses.
Offler claimed that the X48 could support up to 64Gb and that he read it in the techsheet.
Don't know where he read that cause I already went through it a while back and never saw that claim.
This is what they have to say about memory capacity in their X48 datasheet :
https://www.intel.com/Assets/PDF/datasheet/319122.pdf
On page 19,
<• Using 1 Gb device technologies, the largest memory capacity possible is 8 GB,
assuming Dual Channel Mode with four x8 double sided un-buffered non-ECC or
ECC DIMM memory configurations. Note: The ability to support greater than the
largest memory capacity is subject to availability of higher density memory
devices.>
Yes, the note could support Offler claim, but the most important bit of info is on page 43 : <TOLUD register is restricted to 4 GB memory (A[31:20]), but the MCH can support up to 16 GB, limited by DRAM pins>. So the TOLUD adresses anything below 4Gb and MCH supports 16Gb.
So it all depends on the MB. Did the manufacturer respect Intel design specs or did they neglect a few pins.
Spice003 asked why we were still using our old gear...
It's still my main system and yes, I still game with it.
I do have a small list of games that are way too resource intensive.
And before you diss my system, LTT is a hoot
https://www.youtube.com/watch?v=J8ja79SlA-g
Hope it helps.
