1 - 20 of 20 Posts
Which do you prefer,
x800 GTO 1(or2)
or X1600pro ,
People keep talking about the GTO and GTO 2 x800
but the x1600pro seems to have the same amount of pipes (12) and
a much higher clock speed and memory speed. Prices are similar
So i'm stuck on which to choose , please indulge
By the way , I've checked like 15 different X1600pro cards but neither seem
to support a memory bus of 256mb, only 128 ... why would this be ?
thank
x800 GTO 1(or2)
or X1600pro ,
thank
The GTO2's unlock to 16 pipes to a full X850 xtpe
Originally Posted by Peroxide
Well, it unlocks to 16 pipes, but not "into" an x850XT PE, although you can usually overclock to the speeds of one with a stock cooler.
you can flash it "into" X850XTPE, it will perform like it but without VIVO
I thought flashing it with other bios was dangerous and you should just use the modified x800 GTO2 bios someone created.
nah, you can use the x850xtpe bios, thats what i did for mine and it works flawlessly (it run faster than the overclocked gto2)
I thought the GTO2's already come with 16 pipes as a standard, so are they locked when the card is purchased?
How about the GTO 1 cards , they are still better you think ?
Connect3D (I think) started releasing x800 GTO2 with 16 pipes since everyone was flashing the 12 pipe ones. Sapphire still releases 12 pipes as far as I know.
Not sure about the GTO thing though.
Sapphire releases 16 pipes now, eventhough most website will post 12 pipes, when you get the card, it will be 16. How do i know? I bought 3 of them already
SM 3.0 is Shader Model 3.0, which you need for DX9.0c . It makes games run nicer, and will become a standard sometime in the near future.
The GTO1 can be flashed to a x800xl or a x850xt depending on which core you get, r430 and r480 respectively. The r480 will be able to overclock the core speed alot further.
Just a side note, my x800gt is currently running a modded x850xtpe bios with speeds of 535/560 from 475/490, and stock cooling. No pipes unlocked though, still at 8/6.
Discussion Starter · #18 ·
By R480 you mean the core clock , or structure of something
1 - 20 of 20 Posts
