1 - 8 of 8 Posts
I've got a question about my AGP GPU, I was hoping to increase the voltage to this thing to help me reach a higher clock. I trolled the forums on this and read a little about hard-modding the board, which is fine, I don't have any problem with that cause I just sucessfully hard modded my MoBo. My question is, my MoBo allows me to alter the 'AGP VDDQ voltage' from 1.50 - 1.60 - 1.70 - 1.80v, will this setting increase the voltage to the GPU the same way a hard-mod would? Currently I've got it at 1.50v, what's a safe voltage range? These are by no means small increments, especially if you want to keep the temperatures as low as possible, any advice would be great<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Wouldn't that setting be for the AGP bus's voltage? Not the actual GPU voltage...<br />
<br />
I think that setting would only change with a higher end card which demands more voltage than your X800 is drawing... As far as I know, raising the mobo's AGP voltage won't raise your actual vid card voltage. I may be wrong though.
<tr>
<div>
Originally Posted by <strong>Noble Savage</strong>
</div>
<div style="font-style:italic">I've got a question about my AGP GPU, I was hoping to increase the voltage to this thing to help me reach a higher clock. I trolled the forums on this and read a little about hard-modding the board, which is fine, I don't have any problem with that cause I just sucessfully hard modded my MoBo. My question is, my MoBo allows me to alter the 'AGP VDDQ voltage' from 1.50 - 1.60 - 1.70 - 1.80v, will this setting increase the voltage to the GPU the same way a hard-mod would? Currently I've got it at 1.50v, what's a safe voltage range? These are by no means small increments, especially if you want to keep the temperatures as low as possible, any advice would be great<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>The short answer is no, I hope you found my guide easy to understand <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
You will have good results at 1.55-1.6 vgpu if you have a good air cooler, its probably around 1.3-1.4 right now
Upping the agp slot voltage can fry the card
Increasing the AGP bus speed makes for a very unstable environment. Just increse the clock on the chip with AtiTools or TrayTools
Discussion Starter #6
Hey Mister Crowley, I checked out your guide and noticed that it was for NON PRO cards, can I still use it as a general outline for the volt-mod?
If your pcb is printed the same way it will work, but it very well may not be. (look for the voltage regulator)<br />
<br />
If you havent already, take a look at it, I thought you might have checked
1 - 8 of 8 Posts
