Hi guys,
I have an X800 XT (AGP) with Artic Silcencer 4 Cooler + Ramsink. I've been trying to OC it using ATI Tool. I did 4 tests, the results are displayed below
The tests start off and the temp rising normally as it should, but then the test will appear to stop, the 3d stuff keeps moving etc but its almost like ATI Tool has stopped trying to find more CORE ... the first 3 tests all stopped and the 4th test which was high, lost signal to monitor so was forced to reboot the machine
Results:
1.) 570.38 core @ 53º - stopped after 6mins
2.) 556.88 core @ 53º - stopped after 4 mins
3.) 516.38 core @ 52º - stopped ater 1-2 mins
4.) 591.26 core @ 54º - monitor went off and had to reboot
Idle temp for the card is 29-30º
Why would it stop attempting more core? Any ideas?
Cheers
James
Results:
Cheers
James
