1 - 7 of 7 Posts
hi there i have an x800gt and would like to know if it can be unlocked
CONFIG_DIE_FUSES : ffff6fff
CONFIG_SUBSTRATE_FUSES : ffffff9d
CONFIG_REGISTER_FUSES : 00000000
CONFIG_ROM_FUSES : 00000862
thanks
Your pipes are locked via the die. I have the same card as you. Which brand is yours? If you have the r480 core you should be able to overclock it pretty well, and also flash to a modified x850xt(pe) bios. If you have the r423, you won't be able to OC the core as well, but you should be able to flash to a x800xt(pe) modified bios. Note that flashing to either of these will not unlock to any more pipelines, but will raise performance.
I got a Powercolor x800GT. That would be an r480* core wouldn't it? I'm too lazy to turn off my comp and take off the fan and stuff to check. :p
1 - 7 of 7 Posts
