1 - 8 of 8 Posts
Hi,
My X800GTO FireBlade (R480 core) is refusing to go more than 590/500 mem/vpu clock respectively. it gets errors in ATITool. Any way of rectifying this? Upping hte PCIE voltage or have I pretty much pushed it to the limit?
L
Strange.. are you sure you have the Fireblade Edition?
I've been running mine 550/600 with no hitches.
You have the double slot cooling solution right?
Discussion Starter #5
nay - a much larger sink. it just won't go further without artifacting
i think that hs isnt very good. is it the schooner? either way check temps. i have a gto2 and it does 545/575 no matter the temps. some do better some do worse. like cpu's some overclock a ton some a little and some really suck. you seem to have an ok card.
Discussion Starter #7
Not very good?! It dropped from 35 to 29 on idle, with the fans pretty much off
No, thermaltake CL-G0003
not insulting your card, just thought it was a schooner which i hear suck. 29 idle is amazing but your room must be very cold. after reading a review i would assume you hs does great on idle but doesnt allow for the best load temps. anyway it probably has nothing to do with temps, your card is likely just maxed out.
1 - 8 of 8 Posts
