X800se?
935 5
I heard theere is a x800se out and i found it on newegg.com. Would u buy this or a 9800XT or a 6800plain? thanks. which has better image quality?
1 - 6 of 6 Posts
The x800SE is on the front page as a special with newegg.com, i would still recommend the plain 6800 so it can overclock to GT standards which are better than x800PRO standards if you were to overclock the SE.
X800SE I believe only has 8 pixile pipes (?) thereby making it only slightly better than a 9800XT, I too would recommend a 6800 standard, but it only has 12 pipes compared to a GT's 16, but you can still get alot of performance out of it
1 - 6 of 6 Posts
