1 - 2 of 2 Posts
K, I have successfully modded my x850 pro to and xt with all 16 pipes. But I think I have done something wrong. I am currently running 502/570. any time I go any higher on either one the screen freezes. This is really weird, cause I was running at 540/580 before I flashed. I think I used the bios to the wrong kind of mem. I dont know this is what it says on my mem
samsun 510
k4j552340f-gc16
I dont know if it is 1.6 mem or 2.0. I flashed with the 1.6 bios. I dont know if this is the problem, but I think I should be getting a better OC. I am out of ideas any help will be appreciated!!!!
Unlocking extra pipes means creating more heat. You probably aren't able to achieve what you were before because of this. You might try an aftermarket cooling solution such as this. Very popular and great performer.
1 - 2 of 2 Posts
