1 - 20 of 22 Posts
5GHz
Hey all,<br><br>
Im new to 3DMarks and I cannot understand why i nthe GPU test I am getting 4-15 fps... is this normal?<br><br>
I have a 3DMark score of 2010 3DMarks and i dont know if it should be higher than this, my specs are:<br><br>
Dimension 8400<br>
Intel Pentium 4 CPU 3.00GHz HT<br>
1024MB RAM Un-Buffered<br>
Windows XP Home Edition<br>
Sapphire Radeon X850 XT<br>
And an intergrated sound card <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
Thanks in advance.<br>
Daniel
Reactions: |2A|N
I got that score in 3d mark 05. So it seems normal
Reactions: DanielF50
Its because the x850xt doesn't support HDR or Shader model 3.0 which is half of the 3dmark06 benchmark test. Download 3dmark05 and test that for your card... <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"> Another thing that might help is get some nice custom drivers...
Filthy Casual
I think 06 runs graphics that are best suited for ATI x1xxx and nVidia 7xxx series cards, so your card won't be as good at it as a newer card would be. Also, another GB of RAM may help a lot. However, that is still a great card that can run any game at good detail and get good framerates. It just won't look as good at games like Oblivion as an x1800 or x1900 would. I would also recommend running 3dMark 05 or even 04, and the Aquamark benchies are good, too.<br><br>
Welcome to the forums, and if you could fill out your system specs in the User CP you wouldn't have to do that^ in every post.<br><br>
Yours Truly,<br>
pow3rtr1p
5GHz
Discussion Starter #5
wow, thanks for the fast reply's O_O<br><br>
ok, ill try 05 and ill fill out my sig thingie <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
Daniel
<div>Originally Posted by <strong>DanielF50</strong></div>
<div style="font-style:italic;">wow, thanks for the fast reply's O_O<br><br>
Daniel</div>
</td>
</tr></table></div>
No problem.. <img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb"> .. Please report back with your 3dmark05 score <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
5GHz
Discussion Starter #7
woo, 5008 For 05 <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
Daniel
<tr>
<div>
</div>
<div style="font-style:italic">woo, 5008 For 05 <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
Daniel</div>
</td>
</tr>
</table>
</div>5008? That is lower than it should be. You should be pulling at least 5800stock if not 6k.
5GHz
Discussion Starter #10
now, 5445 :|<br />
<br />
Daniel
Not bad, not bad... although Xeoc is right you should be able to reach 6k.. If it wasn't a Dell overclocking your cpu would have helped tremendously...
5GHz
Discussion Starter #12
with certain programs i can... but im not willing to try to blow up my pc... just to get better fps :/<br><br>
ill set the clocks on my graphics to 440 Core, and 600 / 590 Mem...<br><br>
ill post the scores again <img alt="" class="inlineimg" src="/images/smilies/wink.gif" style="border:0px solid;" title="Wink"><br><br>
o and i found a fix for the sqeeching sound my card makes if i have ati tools! <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br>
Daniel<br><br>
*EDIT* only 5775?, erm.. ***? what speeds could i clock my proccessor to... max...<br><br>
Daniel
5GHz
Discussion Starter #13
sorry to double post, but if i flash my card to X850 XT PE would it perform better? if so, can i actually do it? because i cant find any posts about it on google.<br><br>
Daniel
<tr>
<div>
</div>
<div style="font-style:italic">sorry to double post, but if i flash my card to X850 XT PE would it perform better? if so, can i actually do it? because i cant find any posts about it on google.<br />
<br />
Daniel</div>
</td>
</tr>
</table>
</div>just oc to 540/560
5GHz
Discussion Starter #16
well for counter strike source, ive got 540 / 600 and it doesnt make any difference :S<br />
<br />
Daniel
whats the highest your core is hitting?<br />
<br />
edit:<br />
<br />
flashing to x850xt pe will do now performance increase over o/cing to 540/560
Administrator
<tr>
<div>
</div>
<br />
Daniel</div>
</td>
</tr>
</table>
</div>It would perform better as you will have increased clocks and enabled more pipelines if there not already active. However only flash if your card can handle the temps of a X850. You will need to overclock to X850 speeds to seee if your card can cope with it first.
Very true enterprise, stock coolers just don't cut it when tweaking clocks/memory and or flashing bios.I have been down that path and the difference was a staggering 80/85 deg c. to 47 deg c. with max core and mem.
For <a href="http://www.techpowerup.com/bios/" target="_blank">flashing go here </a>but it will not make any difference than doing an easy software overclock.
1 - 20 of 22 Posts
