1 - 20 of 33 Posts
I have a X850Pro AGP VIVO, serial 18054- with fuses of
CONFIG_DIE_FUSES 0xFFFFBFFF
CONFIG_SUBSTRATE_FUSES 0xFFFFFF9E
CONFIG_ROM_FUSES 0xA60
GB_PIPE_SELECT 0x12B84
(yeah, I already know it's die-locked)
The serial is on the box as well, so now we can figure out what card to buy. Although we'll have to buy it in person.
10854
config_die_fuses 0xFFFF7FFF
config_substrate_fuses 0xFFFFFF9E
config_rom_fuses 0x860
gb_pipe_select 0x227A4
Discussion Starter #6
Originally Posted by captain spaulding
18054
CONFIG_ROM_FUSES 0x861
GB_PIPE_SELECT 0xAD46
not sure if it's 16 pipe unlockable
Your pipes are locked via die.
Keep the info coming!
I was able to find a 18052 at a local Circuit City, i'm gonna do a strait swap claiming my current card as defective and see how it mod's.
Discussion Starter #8
Great idea!
Keep us posted dude!
Originally Posted by mackid
Mine was die locked.
S/N 180536002526-D1
Hope this helps.
mackid
...but you can be an hardmod to reactivate the pipe...try it!
CONFIG_DIE_FUSES 0xFFFFFFFF
CONFIG_SUBSTRAE_FUSES 0xFFFFFF9F
GB_PIPE_SELECT 0x2724
What can you tell from mine?
I got the 18052-, it unlocked like a dream, has 1.6ns ram and is running at 550/580 on stock cooling. ^_^
Fuses (for refrence) are
CONFIG_ROM_FUSES 0x860
GB_PIPE_SELECT 0x3FE4
Hey guys, first time poster!
Well, my card has the 1.6ns memory and VIVO and the stuff from ATI tool says:
CONFIG_DIE_FUSES 0xFFFFDFFF
So are the pipes unlockable?
Discussion Starter #19
Awesome!
Please remember to post your cards serial number.
Savage,
As most of you have realised now if you have a X850 pro with the serial number 180540, then theres no hope in flashing it, these seem to be mostly connect3d ones or those bought in the last quarter of 2005.
If your lucky enuf to have a serial number which is either 180510 or 180520 then you will be able to flash.
(I aint sure what can be done with serial number 180530)
Another way of checking is to see what serial number you have on your ram, it is to my knowledge that if its 1.6ns or GC-16 it can be flashed, 2.0ns or GC-20 can't.
But the ones that can't be flashed can be safely overclocked to beyond platinum edition speeds on stock cooling.
1 - 20 of 33 Posts
