1 - 17 of 17 Posts
i got my x850pro agp today and i got ati tool and did the hold down shift thing and clicked settings and it said there are 16 Active pipelines so did my card come with 16 pipelines already unlocked or does this just mean i have 16 pipelines and im only using 12 and also can someone tell me what the x850xt speeds are thanks <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
The xt speeds are 520/540(1080)
lol wow my card is already a x850xt (basically)cause in ati tool it says 520.24/540.00 so my card must already have the pipes unlocked and be 520/540 like the xt
thats awesome hope some luck too u!! <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
nice dude
Discussion Starter #6
1 more question umm how do i enable my VIVO cause i hooked everything up and nothiong happend i think i need a program like wincoder or something anybody have any suggestions
Vivo is only on the xtpe version, all others just have video out you tell this by seeing if you have the ati rage theater chip on the back of the card
Discussion Starter #8
wow thats dumb then why did they give me all these cables
So that you can use a tv with you rig
<tr>
<div>
Originally Posted by <strong>frostbite</strong>
</div>
<div style="font-style:italic">Vivo is only on the xtpe version, all others just have video out you tell this by seeing if you have the ati rage theater chip on the back of the card</div>
</td>
</tr>
</table>
</div>how so? my x850xt is vivo and its not pe. That's not true
flash the card to an XTPE, and then try the Vivo Software. <br />
<br />
It should work anyway, did you try restarting after installing the program?
Discussion Starter #12
well the problem is i dont have any vivo software
Discussion Starter #13
also turns out this card is a great overclocker i got it 560/600 and my highest temp is 66c but what temp should i stop at
Not a set temp per se, just bench the snot out of it or check for artifacts using ATI Tool.<br />
<br />
My x850xt pe rocks out on water...If you went with a silencer, you might even get more speed out of it!
Discussion Starter #15
well umm what exactly is a artifact cause when i overclock to like 540/580 and i click scan for artifacts abunch of yellow dots come up on the screen are those artifacts ?
Yessir <img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin"><br><br>
As already mentioned you will probably want a better cooler on that animal
Discussion Starter #17
k thanks <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
1 - 17 of 17 Posts
