1 - 2 of 2 Posts
hi,i have a question<br>
i have x850xt, and i downloaded atitool beta about half a year ago, when it was finding max, my computer was always rebooting after some time, that made me scared so i stopped o/c<br>
it was 0.25 beta ?<br>
so should i o/c and which of betas i should use.<br>
and btw can somebody tell me about changing fan settings and all the hard stuff and where can i see temp of videocard?<br>
thanks
ATI tool should show a temp monitor in your task bar..<br><br>
Further than that you can better overclock it manually, just take it 5-10Mhz higher at a time, then play a demanding game (like oblivion) to heat it up. Then after 10 mins go back to windows and set the speeds 5-10Mhz higher again. Keep doing this untill the game shows artifacts, then go back and lower it a few mhz and try again. Also don't let the temps go higher that 85C<br>
I might be able to take higher but it won't like it (sometimes decreased performance)
1 - 2 of 2 Posts
