1 - 10 of 10 Posts
my card hits a wall at 549/600... it bothers me alot. I hoped for at least 580 on the core, but it artifacts and locks up over 550mhz. The ram overclocked surprisingly well to 600, but at 610 it artifacts. What next?<br />
Do just have a bad card, or do need to vmod?
you dont neet to water cool, but you will need to up the volts for the core and memory if you want more clock speed.<br />
<br />
Or maybe some new drivers? they have been known to help get better overclocks
Discussion Starter #4
Im running cat 6.2s, thats all that supports win 2k<br />
anyone know if the core can be vmodded with a pencil?
did a quick google and couldnt find anything, thought you could raise the volts with the control centre ?
Discussion Starter #6
no voltage can only be raised by hardware mods. The X1800 and X1900 series can be software coltage regulated<br />
<br />
im checking out vr-zone right now
Discussion Starter #8
nice, i now have a three post chain...<br />
Does anyone else with an X850XT hit an o/c wall at 550 core? Mine is a sapphire model from newegg (non PE, no vivo, no dual dvi)
Try upgrading the cooling, im assuming your using the stock cooler... You could start by removing the stock cooler and applying AS5 to it. The go get yourself a vf-900 or <a href="http://www.sidewindercomputers.com/thhr.html" target="_blank">this beast</a> and a 90mm fan! That i bet will help it get to 570-580 core if you dont already have aftermarket cooling for the card.<br />
<br />
Then after you get colling under control, and are still not satified with the higher clocks, volt mod it.
<tr>
<div>
Originally Posted by <strong>sandiegoskyline</strong>
</div>
<div style="font-style:italic">there is a guide on techpowerup, ill look into it<br />
any other ideas?</div>
</td>
</tr>
</table>
</div>My guide is a bit easier to understand than the techpowerup guide.<br />
<br />
You won't nee'd the memory mod as much as you will need the added vgpu
1 - 10 of 10 Posts
