MSI has 2 types of "Super Ferrite Chokes".Originally Posted by ziggystardust
How you know that MSI's SFCs are 45A rated? As far as I know they are 60A according to previous MSI datasheets.
Even z87 series msi boards seem to have 60 amp chokes. http://media.msi.com/main.php?g2_view=core.DownloadItem&g2_itemId=105157
Not sure if its 8 or 16x.
To be honest, choice of motherboard is not likely to make a big difference in overclocking and benching, although I would recommend the one with the best VRM and the most stable BIOS.Originally Posted by Spectre-
can someone tell me here whats the best mobo for benching ( pushing high/mild clocks for physics score in 3d benches) from the following -
MSI X99 SLI
Asrock Extreme 4/6
MSI X99S Gaming 7
Asrock X99- WS
Asus X99A
GB X99 Ud3/UD4
GB X99 Gaming 5
reasons i have listed these mobos is because these are between $300-$400 in Australia
They are hybrid analog:digital this generation. In practice though, it will probably not make a huge difference.
Informations by Asus tell they use IR 3555 Powerstages
Who wants to see these different VRMs under a thermal camera? ;DOriginally Posted by CrazyElf
Another consideration might be motherboard layout. You want a motherboard that can support at least 2 GPUs, ideally with 4 slot spacing between them (allowing the cards to breathe).
I cannot vouch for the reliability of the midrange Mosfets; I would expect though that when it comes to reliability that the higher end boards will in general be more reliable in this regard though.
What a question
you know what, if I have time this weekend ill do it. I was waiting for a package to come today, but UPS truck showed up 3 hours late to the facility over 12 hours ago, and so its delayed 4 days, oh and because of bad weather that doesn't exist.
+1 to this
no i want to know what makes the asus 8 phases better/ equal to the asrock 12 phasesOriginally Posted by IluBabe
As the name tells the Asrock X99 WS is a Workstation Board like the ASUS X99-E WS. They are meant for stable 24/7 usage without care for oc much. In the end when you chase for high clocks get a oc Board. Potentialy you can get more wattage through the 12 phases but you don't have all the little setttings you have on a oc board to squeez the cpu out.
Eight true phases (vs. six with doublers on the ASRock) and potentially a controller with less overshoot/less need for vdroop. However, the ASRock setup does look like it should be able to handle more current.
oh ok coolOriginally Posted by Blameless
I would be pretty surprised if the VRM was anywhere near the limiting factor for on either the ASUS or ASRock (or most other X99 boards) unless you shooting for some pretty insane clocks with exotic cooling.
by given information in this therad the "A" ("S" since it is between) and "PRO" use 8x ON Semiconductor NTMFD4C85N - and when the pwm is the same they should behave the same. You only get for your > $50 bucks the white color frame, and WLAN 802.11a/b/g/n/ac, Bluetooth 4.0, inkl. M.2-PCIe-Adapter (ASUS Hyper M.2 X4). So in the end nothing to be excited about.
