Here's some info on the Xbox 2.
The Xbox 2 will be called the "Xbox Next". There will be 3 versions of the Xbox Next. The cheapest Xbox Next will be only for Gaming, Music and Video will may have web browsing capabilites. The 2nd best Xbox Next will cost a little more becuas eit will contain a large hardrive for storing music, patches, Video, Possibly downloads, pictures and other things. It will be the Same as the cheapest Version but with a harddrive, that's all. The Most expensive Xbox is the best by far. It will contain a larger Hardrive, an Operating System based on windows NT (but will look alot better), it will basicaly be a PC playing Xbox Games and PC Games aswell as being able to run any Software 32-bit or 64-bit.
You may also be able to upgrade parts down the road (possibly).
Specs:
The Core: The Processor will consist of a IBM processor. It will contain 3 cores on a single Die. Each Core will operate at 3.5Ghz and each core will be able to run 2 thread which means it will be like running 6 processors. each processor will have certain tasks assigned to them.
Grapahics: The Graphics core will be based on the R500 or R520 ATI chip. It will have a core speed between 500Mhz and 600Mhz and will share the memroy of 512Mb with the system. It will have HDTV Support and will include a Superset of PS and VS 3.0+. It has alot more cool stuff aswell
Games: The games will have incredible graphics and will be on 2 types of discs. The discs are HD-DVD which is a single layer disc that can store 15GB of data. They'll also have a Dual Layer HD-DVD disc which will be (you guest it) 30GB. The graphics are going to be absulatley amazing.
Please add any info or discuss.
I wonder if they'll make a R520 chip for PC.
Specs:
