xbox 360 xclamp fix e74 not overheating
34610 Views 32 Replies 10 Participants Last post by  xbox12
hello could anyone please help i,ve tried to fix my 360 with the xclamp fix kit after i had the e74 error i,ve followed the guide and when i get to switch it back on and wait for it to overheat and switch to 2 red lights flashing it stays on 3 flashing red lights and it,s not overheating as when i put my hand on top of the heatsinks there not hot. please could anyone help?
1 - 20 of 33 Posts
Take the exhaust fan out and put it on top of just the cpu heatsink by laying it part cpu heat sink and resting on the dvd drive than turn it on. The point is to only let the gpu overheat.
hello thanks i,m now trying hair dryer when i done that with the fans they started when i first switched the 360 on but then turned off straight away
Take two CDs, lay one on the GPU sink, the flat one. Then lay one standing up on the GPU and leaning against the CPU. Do the heat up for 15 minutes with a COOL HAIR DRYER, It has to be COOL, blowing only on the taller CPU heatsink.
After 15 minutes, remove the cool blow dryer, and then within two-3 minutes it will go to two red lights.
You don't need the exhaust fans plugged in. But if you do that, make sure the air is blowing onto the CPU only. You need to block the heat,
hello, okay your'e saying take 2 cd's, lay one flat horizontally across the top of the gpu sink, i gather this is the lower one of the 2? then take the 2nd cd and put that vertically up against the side of the cpu sink, the side that meets with the gpu sink so we are creating a backwards L shape? then your'e saying take a hairdryer with a cool setting, not hot, and place that blowing downwards onto the cpu heat sink (the taller one) on cool setting for 15-20 mins? well how will it over heat whilst blowing cool air, doesn't it need to be hot? and isn't it the gpu that we are trying to overheat? I'm sorry to question but I have never done this before?
You're confused. The CPU, the taller heatsink needs to stay COOL for 15-20 minutes. The GPU, the small heatsink that is almost flat needs to be hot. Hot like burning hot. Putting two CDs makes the backwards L which keeps the cool air from blowing onto the GPU. After 15 minutes, remove the cool air dryer from the CPU and let it run with no air blowing onto it for 2-5 minutes. That will overheat the CPU enough to make it go to two red lights.
As soon as it's at two lights, unplug the power and let it cool for 20 minutes. You can speed this up by setting the cool air blower in the area blowing onto both heatsinks.
So, if you're still confused, you have to heat up the GPU, but keep the CPU cool. If they are both hot, you will not fix it, and if you have them both cool, then it will not go to two red lights.
So, cover GPU (The small heatsink), and then blow cool air onto the CPU for 15 minutes.
Then, remove the cool air and run it for 2-5 minutes with no cool air blowing onto either heatsink.
It will turn to two red lights. At that moment remove the power and then cool it off for 15-20 minutes.
This is a picture of the last process I did. Do it similar to this:
After the 15 minutes, the GPU will be extremely hot, but the CPU has to stay cooled down or else it will overheat too early.
Remove the cool air, and it'll go to two red lights signalling a overheat within 2-5 minutes. Unplug the power and then cool it down for a good 20-30 minutes. The longer it's cooled down the better chance you have of it working well.
ok i,ve done what you said and the gpu sink is not hot and i still have 3 flashing red lights
Then you did the X-Clamp improper. You need to take it off, clean the paste, apply new paste, then put it on again.
If it's not hot at all then you have another problem or the X-Clamp fix isn't connected correctly.
the light is orange on the psu and the fans switch of after a second. what could i have done wrong?
That's a different problem. If it's not even properly turning on then that's something more than just the X-Clamp can fix.
I would take it out of the shell and remove the heatsinks and try to do the fix once more and make sure you didn't short anything.
You did use Nylon washers to touch the board, right?
If you didn't that could be a problem.
You need it to be screw-washer-nylon-motherboard-nylon-washer-heatsink
If it turns on and immediately turns off...u fried the motherboard.
i used steel washers and the fan turns on then off straight away
Did you not bother to read what I said above?
You need to remove those immediately. That's shorting the board.
I love when people don't read.
You need to get 16 Nylon washers. You put them under the metal washer so that the nylon is only touching the board.
No wonder it's shorting out. I'm not surprised if you killed the whole board for not bothering to read.
|Screw|Metal|Nylon|Motherboard|Nylon|Metal|Heatsin k|
Man it doesnt matter there is nothing that can short, around where the screws go in. Did they use nylon washers with the original x clamp?
Mine used to go screw, spring washer, board, nylon, washer, heatsink. But that only lasted about 6months. Ive now taken the spring washer out so it goes screw, board. Seems to have fixed it.
His problem does sound like it shorting out somewhere but i seriously doubt it will be anyhting to do with the washers.
ok you say its shorting out so i took it out of the case and still the same and i have just ordered a new xclamp fix kit with nylon washers?
You're a moron. The original X-Clamp isn't having contact with the board directly. Using a washer is being contacted directly to both sides of the board. Yes, it is bad having direct metal touching that area, and yes it can short out. I know what I'm talking about.
Obviously you dont. The bolts that connect to the heatsink from the xclamp do have direct contact with the motherboard... THERE IS NOTHING THAT CAN SHORT THERE
! You see the gold rings around to screw hole? thats to stop the bolts from shorting it. Infact the spring washer that i had on before scraped of the PCB around where the bolts go.
What your basically saying is you should use nylon washers when you screw down any motherboard..
come on please I never wanted to start an argument I just needed help fixing my 360. No virtual fighting LOL!!!!!!!
Sorry man.
You may have actually shorted the motherboard another way. 360's have a floating earth point or something, its not like PC's. They can short very easily, im thinking you may have permanently damaged the motherboard
By not earthing your self properly.
1 - 20 of 33 Posts
