1 - 8 of 8 Posts
I am having an issue with the optical drive for my Xbox One. The drive will not read/load games anymore. When I try to load a cd/Blu-ray it is pixelated and choppy.
Before when I was having these issues, I could find a game that I have not recently played, allow it to start loading, before ejecting the game and choosing the game I actually wanted to play, and it worked about 80% of the time. Now even cleaning the disc consecutive times before reinserting it does not work.
My Xbox is long out of warranty. Is there something I can do to fix it myself? If not, where can I take it to, to get it fixed? Do they sell optical drives for the Xbox One that I could connect USB? Any help would be appreciated!
No, I haven't. How hard is it really to open it? I'm the kind of guy that loves taking things apart, but not too good at putting them back together. Also, I don't really want to break it.
Discussion Starter #4
Wish they would have made it where you could just eject the whole drive easily instead of having to open it. Not really sure how to open it either without damaging it.
Overclock Failed...
There are plenty UTube videos.
I would just replace the drive as cleaning rarely works or lasts. Replacement drives can be found from third party sellers here:
Newegg
Amazon
Gamestop repairs them with a flat rate plus the part. Check them out as well if you don't want to do it yourself.
1 - 8 of 8 Posts
