1 - 13 of 13 Posts
Hi everyone,
I'm constantly facing problems with in-game controls due to their lack of custom tailoring possibility)
There are always a few button layots to choose from, but you cannot remap anything as you wish.
For example I want to use "X" button to "RUN" in "Resident Evil Zero HD Remaster" instead of "B" button.
How can I do it?
(Maybe there is any universal software or tweaking hint that can help you?)
Getting used to 'new'
MotionInJoy allows me to use my third party PS3 controller as a 360 controller for emulators and a game I've got that won't work at all with it by default. It's a little confusing at first, but you can remap inputs from different devices with it.
You should be able to map your controller to swap the buttons around that your want.
Discussion Starter #4
I'll try MotionInJoy if it can swap the buttons around.
As for the Xpadder, I've never found any way to swap buttons there. As far as I know you can only assign keyboard buttons for your gamepad with it. But if I'm wrong, provide me with a tutorial please)
Discussion Starter #7
Originally Posted by thuNDa View Post
x360ce: http://www.x360ce.com/
Well I couldn't swap buttons around there, couldn't find anything like that. But anyway, it is a quite sophisticated method. I don't understand why we just can't remap buttons in game options like we used to do all along
I found a program named " Durazno v0.6-18 " - it does exactly what I want, super easy and understandable, though it doesn't seem to be very popular and known, so it may have a lack of support for many games or even newer Windows versions etc.
Have you seen my Baseball
I know that a wireless 360 dongle and a wired will work together. I've never personally used two wired 360 controllers, but I don't see why it wouldn't work.
The one i am using is working beautifully just concerned before purchasing 2nd one for versus mode.My concern is that the pc might see both controllers as player 1 gamepad
1 - 13 of 13 Posts
