Xfire
615 Views 11 Replies 8 Participants Last post by  DomeD-
If i xfire a 4870 and a 4890 with it default to the lowest graphics card?
So it would be like 2 4870's
1 - 12 of 12 Posts
No.
CrossfireX (unlike SLi) keeps the cards at the clocks they had before. It simply splits the work between the cards.
No, it would downclock the fastest card.
I've used 4890s of different speeds (much less different cards all together) and clocks were downclocked to the lowest clocked card. I dont know if they've fixed that since the 9.7 drivers but that was my experience.
Hybrid Crossfire Downclocks.
Originally Posted by Tator Tot View Post
No.
This is correct, all others wrong.
Together, it will give slightly better performance than just 4870 CrossFire, by around 5-10%.
Just clock the 4870 to the 4890 speeds.
And yes.. It downclocks.
Only problem is that most 4870s cant hit 4890 speeds stable. You can however hit a point where the 4870 is maxed out that could be close to a 4890.
NO it does not downclock.
CrossfireX does not downclock cards, this is why you are able to run a HD4870 in Crossfire with an HD4850 or HD4830 or HD4890.
All the clocks stay the same.
I have a 4850 and a 4870 and have run them both in x-fire, and it never downclocked the 4870 to the 4850. Once my son has finished on his comp, i'll re-install the 4870 + 4850 in x-fire if need be and post screenies.
If I recall correctly (the 4850 has 512MB 4870 1024MB) it never dropped the 4870 to 512 either, but don't quote me on that, not 100% till I try it.
Here is an old screen shot of the 4870+4850 in x-fire.
They would both have the same Vram
1 - 12 of 12 Posts
