1 - 2 of 2 Posts
I have a xfx 5870 reference card, not overclocked..
it idles @42c.. and i tried doing a test with occt
I used 1024x768 resolution with max shader complexity 8 and checked "error check"
I opened CPUID hardware monitor to check the temps, and after 1 min, the temps jumped to 83c, so i stopped it..
is that normal?
also, what is the max safe temps for this card?
I'm NOT new to Overclock
Yes, that is normal, No you don't need to worry about it.
Admittedly it's a bit toasty, maybe a TIM replacement, or better airflow within the case. But my 5770 loads at about 73 OC'ed so I wouldn't be too concerned.
C
1 - 2 of 2 Posts
