1 - 3 of 3 Posts
Slave to IaaS
2GB XFX 6950, has unlocked shaders on the second BIOS (First switch position is the stock BIOS)
Doesn't play nicely with the 6970 bios so I recommend staying with 6950 bios.
Had it clocked at 870/1300 at stock volts.
Price stated does not include postage, we can sort that out between ourselves because a lot of people like to use different couriers.
Pickup can be done from Christchurch, Dorset if you're close enough.
Need more pics?, i'll post them up ASAP on here if you request!
EDIT:
Will absolutely not post to any non-UK country, unless you have at least 50 rep, 500 posts and 10 positive feedback in the marketplace.
Slave to IaaS
Provisionally sold.
Note to above user, why did you not PM me?, It took until now for me to notice you had posted here.
1 - 3 of 3 Posts
