1 - 15 of 15 Posts
Some drivers I am using with the 7800 GT is causing my monitor display to mess up. My monitor is not recognized and goes to Analog Display. It bugs me because everytime i click the Nvidia tool or go into settings under my computer, i get a black screen for a little while and then it shows my screen again. What is the problem? And I really want to keep the driver i am using because i get higher benchmarks with it.
Discussion Starter #6
Originally Posted by pandapimp
Is it a modded driver, or the official nvidia forceware drivers?
I tried the Nvidia ones off there website but my benchmarks arent nearly as high as the modded ones. Any suggestions on some good drivers to try?
Discussion Starter #9
And what should my card be benching at with my system specs? I am getting anywhere from 68000 to 78000
Discussion Starter #10
Try the XtremeG drivers. Do you notice the difference in the games you play? I wouldnt worry about the benchmark differences.
Well I play a game called Everquest 2... i can only play the game on balanced, extreme performance being lowest and extreme quality being highest...
Discussion Starter #12
Have you ever tried the official forceware drivers?
Yes... alot slower than that ngo one i linked u
1 - 15 of 15 Posts
