XFX 7900GS 256MB Volt Mod
2313 Views 4 Replies 4 Participants Last post by  tha d0ctor
Hi i recently assembled some old Pc parts of mine, and installed an old 7900GS.
I am really interested in volt modding this card so I can see how far it will OC.
currently i have it at 621MHz on the core stable and 730Mhz on the memory. This is just not enough!!
I have looked over the internet for a volt modding guide for this card to no avail. The other 7-series volt mods are on cards with a different PCB layout than mine.
mine has a MOLEX power connector, NOT PCI-E 6 pin.
here is a picture for reference:
good luck finding the back PCB on google.....
i will take a pic of the back when i get a chance to.
any help is appreciated
thanks in advance
1 - 5 of 5 Posts
thanks in advance
Take some full pics of the back and front w/o cooler. We will try to help you.
ok well i took a bunch of pictures of the back PCB, and i am having trouble uploading them to any site. tried both photo bucket and image shack and no love. will try some others though.....
may be a while
Wumpus just click on the advanced button when you are replying and then you will see the add attachments option to upload them from your PC
Originally Posted by Voltage_Drop View Post
Wumpus just click on the advanced button when you are replying and then you will see the add attachments option to download them from your PC
^^^This
click Go Advanced while you are posting a reply and you can upload JPGs and a few other formats, make sure you take the pictures with the flower/macro setting of the camera to get real detailed and close pics
1 - 5 of 5 Posts
