Ok, now I am starting to think it is Fallout 3 that is the problem.
I am having the EXACT same problem. I have my 9800GT oc'ed to about 750, have been playing multiple games with no problem.
However, it was right around the time I installed Windows 7 that I actually went from an over clock of about 700 to 750. I then could NOT get FO3 to run. I had attributed it to Windows 7 adn a driver. So I tried running in Vista, sure enough it would not run until I down clocked my card back to around 650 or 700 before it would run.
This is a very strange issue. It seems like if it was going to crash it would crash in all games, or at least multiple games, and not just FO3.
I would very interested to see if anyone else is having the same problem.
You can try different software, but it is the same thing I am using.
Yep. That is the way you do it.
The card is junk? I have the same card as you, it SHOULD overclock very well. Have you tried running other games?
What temperatures do you get with the card?
Should I try a different OC software? Or is my card junk? |
Did I overclock correctly and if not could someone point me to a guide. |
