XFX GeForce GTX 260 Black Edition
612 Views 4 Replies 4 Participants Last post by  harrison
Would a 500W power supply be enough for this GPU?
1 - 5 of 5 Posts
Depends on the rest of the system and the 500W power supply in question.
I'll go out on a limb and say yes, if it's a power supply of decent quality.
Depends on the CPU and other choices too, such as the amount of hard drives etc.
http://www.nvidia.com/object/product...tx_260_us.html
500w is the minimum requirement, so yes; it will run but it depends on the other hardware choices too.
Well I have a [email protected] stock,2GB RAM,1HDD,1 optical drive and 5 case fans.I read on a review that the card takes 302W at peak load.
yes it should i ran one with a 450w i7 9g ram and 3 fans
1 - 5 of 5 Posts
