XFX R7 260X 2GB D5 DP HDMI / R7-260X-CDF4 /
Description:
DD RADEON R7 260X 1100M 2GB D5 DP HDMI 2XDVI GPU Clock 1100 MHz Memory Bus 128 bit Memory Clock 6.5 GHz Memory Size 2 GB Memory Type DDR5 Thermal Solution Dual Slot Thermal Minimum Power Supply Requirement 500 watt XFX Recommended Power Supply XFX 550W PSU Max Supported Resolution (ANALOG) 2048 x 1536 Max Supported Resolution (DIGITAL) 2560 x 1600 (DVI); 4096 x 2160 (HDMI;DP)
Details:
Description:
Details:
Detail | Value |
Binding | Electronics |
Brand | XFX |
EAN | 0527222678560 |
Feature | MPN: R7-260X-CDF4 |
Label | XFX |
Manufacturer | XFX |
Model | R7-260X-CDF4 |
MPN | ETM4001-R7260XCDF4 |
Publisher | XFX |
Studio | XFX |
Title | XFX R7 260X 2GB D5 DP HDMI / R7-260X-CDF4 / |
UPC | 527222678560 |
Item Height | 0 inches |
Item Length | 0 inches |
Item Width | 0 inches |
PartNumber | ETM4001-R7260XCDF4 |
ProductGroup | CE |
ProductTypeName | INK_OR_TONER |
UPCList - UPCListElement | 527222678560 |
Item Weight | 2.4 pounds |
