Hi there,
So far my experience with XFX has sucked. I live in the UK and ordered the XFX TS 650W - it arrived but is labelled with a serial number of the XFX Core, so I spent half the morning trying to work out if it was an error (as all the packaging said TS) or whether I needed a replacement. After counting the connectors, it seemed to match with the TS so I'm hoping it's just a mis-print on the label.
Now I'm about ready to plug it in. Except the power cable supplied is a European 2-pin plug, so I don't think it won't work in the UK sockets. This is bought from a UK distributor. FFS.
Anyway. I have another cable that will physically fit the PSU, but before plugging it in I wanted to check it would actually work and be safe, as I am not knowledgable in this area.
The power cable that came with the PSU has this written on the plug:
LP-33
LINTEK
16 / 250
... and on the part that connects to the PSU, it says:
LS-60
10A 250V~
LINETEK
On my spare cable, on the plug is written:
13A 3A
10A 5A
250 F
10/250~
Any advice? Thanks...
LP-33
LINTEK
16 / 250
LS-60
10A 250V~
LINETEK
13A 3A
10A 5A
250 F
10/250~
