1 - 5 of 5 Posts
High IQ Person
My psu is getting very load while playing some heavy games, like metro exodus, the fan just goes full 100% and it's super annoying.
It should be a 135mm fan, can I buy a quieter one somewhere, if it exist?
edit: fixed title
9 Cans of Ravioli
good luck finding a "quality" 135mm fan, kind of a goofy size.
probably would have better luck tracking down a good 120 mm and rigging up an adapter to mount it.
it probably isn't a standard 3-pin/PWM fan, but you can can probably rewire it pretty easily. would have to crack it open and take a look to know though.
Space Cadet
9 Cans of Ravioli
You can replace the fan with a quiet one.https://www.newegg.com/p/1YF-003V-00986?Description=135mm fan&cm_re=135mm_fan-_-9SIAKNJBH66889-_-Product
Or you can rig the fan you have to run off of 5v using a 4 pin molex peripheral connector.
that fan has 120 mm mounting holes and a 135 mm fan blade diameter from what little I can find out about it, still would need to figure out a mount for it.
*edit*: actually maybe not?
https://www.aliexpress.com/item/4000167335761.html
there it looks like it might not but I can't find it on BeQuiet!'s site.
High IQ Person
Discussion Starter #5
You guys are amazing, now I just have to remember how to remove the PSU from this case
1 - 5 of 5 Posts
