1 - 20 of 48 Posts
This may simply be an issue with my particular motherboard (Gigabyte Z77-UD5), but would be interested if others could give it a try.
When XHCI is enabled I notice a large increase in mouse lag. The mouse becomes floaty as if vsync has been enabled. Simply disabling it in bios (you lose USB3) has greatly increased mouse responsiveness.
XHCI enabled - floaty mouse, in-game sensitivity 3 to compensate
XHCI disabled - responsive mouse, in-game sensitivity 4 where it used to be on an old USB2 machine
I have the exact same motherboard and I think that I can notice a little less lag when disabling XHCI. So thanks for suggesting that!
I have also been using both the Usb2 and usb3 port. While they feel a little different I can not tell which one is "better".
Is there a way that you can test your mouselag?
My mouse is connected to USB2. I suspect the motherboard is using a single timing chip for both hubs. With USB3 effectively disabled my mouse movements are much more precise.
The lag is so small most people wouldn't even notice it, so I doubt it can be tested effectively.
I used a little flash game to test it out. Decided that I noticed it enough to just leave XHCI off. If I ever get something that requires usb 3.0 I can just enable it.
I was thinking that the Usb2 ports were on a separate controller considering you can turn it of in the bios.
It's kind of funny how there are a lot of factors that can introduce lag but not a good way to test it.
So I guess it's the same as V-sync, flip-queue, scaling and what have you. If you think that it lags just turn it off.
My mouse acts funny on USB3, I stick to USB2 for everything that is not specifically a USB3 device, like my external HDD enclosure.
Maybe it's different for other mobos, but on mine the USB3 ports are on a separate controller from the other USB ports, so I can still utilize USB3 w/o negatively effecting the stuff plugged into the USB2 ports.
I was under the impression that it would be fully backward compatible. Just like how I didn't notice anything when usb 2.0 was new.
But now I got an external soundcard that pops on the 3.0 ports and I have to worry about input lag.
It's kind of weird how this mobo has only 2 regular 2.0 ports and no ps/2 port. So you have no slots left by just hooking up your keyboard and mouse.
SAME FREAKING PROBLEM !!
I was litterally pulling out the hair out of my head last night !
everytime i moved the mouse i had HUGE framedrops in-game no matter the game ( csgo - insurgency - contagion - RO2 )
Uninstalled the xhci driver and everything went back to normal
Polling was weird on my cm storm alcor too !!
with xchi usb 3-> 1020hz avg
wiithout xchi usb 3 -> 999-1000hz
Plugged a good old intellimouse explorer before uninstalling the driver, i had no frame drops but i could not overlock my port !!
Any ideas on keeping the 3.0 driver AND my sanity ?
Facepalm
I think these bugs ONLY apply to asmedia USB 3.0 chips/motherboards.
The P67 boards with the Renesas (NEC) USB ports are not affected by this at all.
No difference between a USB3 and USB2 port...mouserate and dx_mouse_poll both show 1000 MHz and dx_mouse_timer_dialog shows 1020mhz on all ports and mice even on USB2 (and its even done that on core 2 motherboards).
0 problems and difference for me with xhci enabled in bios and drivers installed on a Asus Maximus Gene V Z77.
I don't have my mice in USB3 either.
Same average and peak refreshrate on 2 different mice with it enabled and disabled.
See no reason to disable it since I need the usb3 for drives.
1 - 20 of 48 Posts
