Xiggy Bolt Through Kit --- How do I get it off?
535 Views 12 Replies 8 Participants Last post by  Interpolation
I'm pretty sure that when I put the backplate on my Xiggy bolt-through kit, there was some sticky pads that attached it to the motherboard. How the heck do I get this thing off without damaging my motherboard?
1 - 13 of 13 Posts
Originally Posted by Jolly-Swagman View Post
heat with hair drier and gently prize off should make it easier to remove!!
thanks, i'll give it a try!
any other tips would be great! using the true with the xiggy backplate is not working out for me :/
Hmm. Heating the adhesive is not necessary and may actually make it harder to remove (stickier and easier to tear). Just gently pull up one corner 20 degrees, move to the next corner and repeat until it uniformly comes off.
Okay thanks!
One vote for heat, one vote for no heat. Any other opinions?
no heat just try and pull it off evenly!
I've done the hairdryer method at least 20 times over the past couple of years. Never had a problem with it yet.
there's really nothing else I can do other than brute force? I tried pretty hard when I was switching from the Xiggy to the TRUE and it wouldn't budge.
Like has been said, any sort of heat is ideal for removing it, that's always what I've done.
Once removed, there may be some residue left, clean that up with some rubbing alcohol if you have any, wait for it to dry, then apply the new backplate.
there seems to be more votes for heat than not so i'll give it a try, thanks!
I got it aswell, i just took a small screwdriver and put it between the sticky pad and the actuall metla plate and carefully remove it.
This is why I never remove the plastic sheet and just dry-fit it on.
1 - 13 of 13 Posts
